graphics on g82 &g84 codes
I have 2 Triac machines both 1986 model
when putting in a canned cycle pocket the machine stops showing graphics at the first centre saying move exceeds machine limit, however the machine produces the correct part and it repeats the cycle on as many times as required until de-activated.
All other profiles linear arc diagonal circles work fine on graphic display.
G55 has been set correctly and I have even put in your program (page 126 of manual stops at g82 prompt) and it producet the job but graphics stop at canned cycle G84
Is this normal or could we have some software corruption?
Re: graphics on g82 &g84 codes
It may be worth seeing if the DOS software we have here is a later version:
Although it may cause you more issues getting it to work again :?
No-one here really knows anything about the old software - it could well be a bug or a setting of the graphics.
I'll ask Mr Magoo to comment...
