These i put in fanucm.opt(.go) or in flstep.opt (.go) ???
the same .opt & .go text do i use with the desktop ????
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
Yes.
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
FANUC_SDEVICE machine
UTILS_MENU_1 Dos Access
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
SLAVE_CONTOURFEED 0.15
SLAVE_CONTOURANGLE 0.15
XIO 1
ATC 0
Fanucmd.opt
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
XIO 1
ATC 0
Fanucmd.opt
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
dir martin
I have done that you write to me but....--->
fanucmd.opt
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
XIO 1
ATC 0
Fanucmd.go
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
it works with FLSTEP.APP ---> instead of FANUCMD.APP
BUT with FLSTEP as i have wrote before i have lathe software in mill machine .
i can't have the control from tutor desk except cooling on ,cooling off.
if i download HEIDEN from 5 1/2" disks in PC and run heiden , the program runs but i dont have control of the machine.
Is there FLESTEP FOR MILL???? OR FLESTP.APP FOR MILL???
fanucmd.opt
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
XIO 1
ATC 0
Fanucmd.go
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
No Flstep is turning software only.
Have you copied the "Drivers 2" directory in to the working directory?
Finally it worked. I am very satisfied and happy
I suspect that the problem they was the cards. I removed and put the all cards, afterwards all via yeast it worked
Your contribution they was despite very auxiliary. I have read a lot in my forum for problem and I acquired a lot of interesting things that me helped I reach in the result.
Thanks particularly Martin and denford Admin and Graham Bradley for his interest and the advices.
Many thanks
Pantemis Gregori
Teacher high school
Lesvos
Greece
Many thanks
Pantemis Gregori
Teacher high school
Lesvos
Greece
Great news - glad it's working again
Did you get it to run from fanucmd ?
What did you need to do to create the correct files ?
Was it just changes to the .go and .opt files or something else ?
The programme that works fine for triac pc with dos was
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
Fanucmd.opt
IBM.RS2 2
$3F8 4 COM1
$3F8 4 MACHINE
DENFORD1.KBD 1
18.2 $2F8 3
VGA.CRT 0
FANUCMD.APP
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
Fanucmd.opt
IBM.RS2 2
$3F8 4 COM1
$3F8 4 MACHINE
DENFORD1.KBD 1
18.2 $2F8 3
VGA.CRT 0
FANUCMD.APP
Dear Sirs
I'm also from Greece (Evia island)) and I have more or less the same problem with a Denford triac pc. The machine is working now with a 286 pc and 5 1/4 floppy discs. I have to load with a floppy first DOS and with an other floppy fanucmd...
I'm trying to change the pc, with a pentium windows XP (service pack 3) that i found spare in my new school, the only one with two male serial 9 pin D ports,
but I took as a result
What do you suggest me to do?
Thank you in advanced
Nikos
Nikos
dir nikos
put a hard disk with windows 95
my email is gpantemis@gmail.com for more informations
greg
greg
