i have stupidly accidentaly knocked the dip switches
for the tool changer- it is for a TRIAC ATC 1990 PNC3 control. the switches are ranked 1-8 if anyone could tell me the correct settings that would be great... cheers...
I haven't managed to find any info on the toolchanger board used in the Triac, but it was a special variant of the North East Electronics SMCU controller that talked to the main Triac controller through it's own special serial link.
Here is an extract from the manual I found on their website regarding the DIP switches on the SMCU (may or may not relate to the variant that controls the toolchanger
NOTE the LED it mentions is located on the PCB in the rear electrical cabinet, not the front panel - I think the "few shot flashes then off for a while" error indicators are valid, not sure about the other stuff about the LED though
https://www.nee-controls.com/legacy_downloads.html
Page - 37
Indicated System Errors
The unit includes a front panel indicator which has a number of uses.
At initial power up if the controller microprocessor is running and the EPROM checksum is correct the indicator
repeatedly flashes On for ¼ second, Off for ¼ second until the first RS232 command is received (if RS232 operation
selected by SW 7) or until the optional keypad is used (SW 7 Off). If at power up the EPROM checksum is
incorrect the indicator flashes On and Off 5 times a second.
If the controller is operating in RS232 mode (SW - 7 On) the indicator changes from On to Off or vice-versa for
each RS232 character received. In normal operation controlled by a host computer the indicator will glow dimly as
RS232 characters are received then will remain Off or On for the period between receipt of characters. Any error
conditions detected by the controller are transmitted to the host in a coded form (see section b).
If the controller is not operating in RS232 mode the initial flashing stops when the keyboard is operated. The
indicator then changes from On to Off or vice-versa each time the keyboard is operated.
Whilst the controller is executing a Dwell the indicator increases then decreases intensity once per second.
Whilst the controller is executing a Wait Until Input command the indicator flashes rapidly.
The indicator is also used to indicate a number of error conditions as follows:-
Error Indicator Operation
Overtravel Error 1 short flash on then off for 2.5 seconds repeated.
Stepper Drive Fault 2 short flashes on then off for 2.5 seconds repeated.
Datum 3 short flashes on then off for 2.5 seconds repeated.
Ext Stop pressed 4 short flashes on then off for 2.5 seconds repeated.
ROM RAM Data Error 5 short flashes on then off for 2.5 seconds repeated.
Command Error 6 short flashes on then off for 2.5 seconds repeated.
When the MC3E, (SMCU/SMCU+ version 007 onwards) is switched on the RS232 interface operates at 300 baud,
7 data bits and odd parity. Systems connected to a host computer should be initialised at this time with data from
the host. If the host computer does not operate at 300 baud, 7 data bits and odd parity the controller will indicate a
command error.
If the controller indicates a data error at power up the internally stored system parameters will have been corrupted;
the system must then be connected to the host computer and correctly initialised before use.
Setting of Internal Assign Switches and Links
The unit has internal switches which enable the unit to be set to operate in a number of different modes at initial
power on after the external ram has been cleared or after an external ram checksum error has been detected.
8 switches only are fitted, their function is as follows:-
SW 8 – Hardware Test Mode Select
If SW8 set On at Power Up SW4 to 1 are used as follows:-
SW4 SW3 SW2 SW1
Off Off Off Off - Not Used
Off Off Off On - Not Used
Off Off On Off - Read/Transmit status of Datums/Inputs
Off Off On On - Read/Transmit status of Overtravels/Link 1, 2
Off On Off Off - Read/Transmit status of Assign Switches
Off On Off On - Read/Transmit status of Ext. Keypad
Off On On Off - Read/Transmit status of Ext. Stop Drive Flts
Off On On On - Sequence Aux 1 to 4 and Spdl relays/LED
On Off Off Off - Execute Auto Test
On Off Off On - Do a 3 axis move
On Off On Off - Ramp D to A output
On Off On On - Checksum ROM and transmit checksum
On On Off Off - Test External RAM (if fitted)
On On Off On - Read/Transmit status of inputs 5 to 12
On On On Off - Sequence Aux 5 to 12
On On On On - Sequence Aux 13 to 20
If SW8 is Off:-
SW7 selects RS232 data transmission from controller if On
SW6 selects either ROM (if On) or RAM program execution from keypad
SW5 selects continuous program execution (if On) or wait for Start between program executions if Off.
On systems with battery backed RAM SW4 to 1 are not used.
On systems without battery backed RAM SW4 to 1 are used as follows:
SW4 selects parity checking of input RS232 data if ON
SW3 selects either Odd (if On) or Even parity for received and transmitted RS232 data
SW2 & SW1 select RS232 baud rate as follows:-
SW2 SW1 Baud Rate
Off Off 300
Off On 1200
On Off 4800
On On 9600
Use of PCB links:
Link 1 fitted for 11Mhz Xtal, remove for 14.756Mhz systems
Link 2 fitted on SMCU, remove on SMCU+
Page - 37
command error.
SW4 SW3 SW2 SW1
If SW8 is Off:-
SW2 SW1 Baud Rate
Off Off 300
Off On 1200
On Off 4800
On On 9600
Use of PCB links:
thanks for finding all that - much appreciated- will try and make sense of all that.. unfortunately the dip switch settings as they are at the moment have effected the tool changer so it no longer works..TOOL CHANGER ERROR!!!!
If anyone has the same machine (TRIAC 1990 ATC) i would like to try their settings for the dip switches and hopefully they would work???
cheers everyone...
cheers everyone...
the dip switches in the rear electrical box under the external monitor only seem to effect the tool changer- its these i need to reset.. the info you gave me does not sort the problem out- i could do with the factory default settings or someone who has the same machine to let me know their configaration..
thanks for any help......
Is the red LED on the toolcange control board flashing at all?
If so, what is it's ratio of on to off times (see my previous post re: status LED)
The toolcanger board contains some batter-backed RAM in order to 'remember' which tool is in the spindle when the machine is switched off. I think this memory may be corrupt.
red light flashes continously with no breaks or pauses. everything worked ok till i knocked the switches- could this have corrupted the memory?? any way to reset?? the machine does not remember the tool in the spindle- it asks after datuming..
flashing LED sounds like the pcb is healthy (i was confusing triac atc with starmill re battery backed ram)
i have had another look around for info but have none. i hope someone out there can reply who has a similar unit.
just a thought... are the cables between machine and atc control box all seated ok?
yeah all cables are ok - i've just gotta get that switch config right and all will be ok.. thanks for all help..
RIP steve... will be greatly missed!!
Hello!
Have you already tried the order "M27 reset Carousel"?
This assigns the current tool to tool 1.
You have for certain this, wanted to enquire only.
Greetings
Enny
Greetings
Enny
cant get to the point of inserting m code and im sure this wont reset the dip switches.. thanks anyway..
this might be over the top, but if its causing you major headaches - then you are guarenteed to get it right within 4.2 hours, assuming a startup time of 50 seconds, and 10 seconds to change the dips.
good ol' binary
00000001
00000010
00000011
00000100
00000101
00000110
00000111
00001000
well you get the idea
0=off or up or whatever
1=down or on or whatever
and once you've found them, write it down, and mabey post it here so that it is forever more stored in the depths of google.
good luck mate
good ol' binary
00000001
00000010
00000011
00000100
00000101
00000110
00000111
00001000
good luck mate
I also do not believe the dip switch be put again into its starting point by it.
My machine dates from 1991 and have an ATC fitted. I can't find the switches described by you, have a photo?
Another idea would be deactivating the ATC in the .opt file, completely start machine once, after some time activate the atc again. This also will not put the dip switch into their starting points, accumulators provide with new tension, possibly however.
the dip switches are located in the rear electrical box fitted to the inside of the door. the switch housing is blue and they are ranked 1-8 - 1 being at the top.. note pics below..
cheers...
cheers...
I think that some of these replys relate to other Control types that Denford fitted.
The M27 only works on the later machines.
The machine Pab has is fitted with a NEE PNC3 control system.
I am sure that when we powered one up that we only had to set the Dip switches in order to set it up.
The toolchanger then Datums automatically after all the axis have moved datumed.
I have tried to find the original info but have not been able to locate it.
I think it is worth trying the switches as sugested above. I am sure that it will not be a long process.
Good luck.
Good luck.
Have you tried contacting NEE ? www.nee-controls.com
They have a manual for the PNC4 controller on their website, but many years ago I got a PNC3 manual from their website in the form of a PDF. I've probably still got it somewhere at home - god knows where. Might be worth trying them first - I will have a look and see what I can find at home.
Dave
Dave
enjoy
Code: Select all
00000000
00000001
00000010
00000011
00000100
00000101
00000110
00000111
00001000
00001001
00001010
00001011
00001100
00001101
00001110
00001111
00010000
00010001
00010010
00010011
00010100
00010101
00010110
00010111
00011000
00011001
00011010
00011011
00011100
00011101
00011110
00011111
00100000
00100001
00100010
00100011
00100100
00100101
00100110
00100111
00101000
00101001
00101010
00101011
00101100
00101101
00101110
00101111
00110000
00110001
00110010
00110011
00110100
00110101
00110110
00110111
00111000
00111001
00111010
00111011
00111100
00111101
00111110
00111111
01000000
01000001
01000010
01000011
01000100
01000101
01000110
01000111
01001000
01001001
01001010
01001011
01001100
01001101
01001110
01001111
01010000
01010001
01010010
01010011
01010100
01010101
01010110
01010111
01011000
01011001
01011010
01011011
01011100
01011101
01011110
01011111
01100000
01100001
01100010
01100011
01100100
01100101
01100110
01100111
01101000
01101001
01101010
01101011
01101100
01101101
01101110
01101111
01110000
01110001
01110010
01110011
01110100
01110101
01110110
01110111
01111000
01111001
01111010
01111011
01111100
01111101
01111110
01111111
10000000
10000001
10000010
10000011
10000100
10000101
10000110
10000111
10001000
10001001
10001010
10001011
10001100
10001101
10001110
10001111
10010000
10010001
10010010
10010011
10010100
10010101
10010110
10010111
10011000
10011001
10011010
10011011
10011100
10011101
10011110
10011111
10100000
10100001
10100010
10100011
10100100
10100101
10100110
10100111
10101000
10101001
10101010
10101011
10101100
10101101
10101110
10101111
10110000
10110001
10110010
10110011
10110100
10110101
10110110
10110111
10111000
10111001
10111010
10111011
10111100
10111101
10111110
10111111
11000000
11000001
11000010
11000011
11000100
11000101
11000110
11000111
11001000
11001001
11001010
11001011
11001100
11001101
11001110
11001111
11010000
11010001
11010010
11010011
11010100
11010101
11010110
11010111
11011000
11011001
11011010
11011011
11011100
11011101
11011110
11011111
11100000
11100001
11100010
11100011
11100100
11100101
11100110
11100111
11101000
11101001
11101010
11101011
11101100
11101101
11101110
11101111
11110000
11110001
11110010
11110011
11110100
11110101
11110110
11110111
11111000
11111001
11111010
11111011
11111100
11111101
11111110
11111111
