Novaturn Dimensioned Drawings
angel-tech
Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3
Re: Novaturn Dimensioned Drawings
Post by angel-tech » Mon 07 Mar , 2011 22:16 pm
no probs, it'll take me a while to get it apart.
Iron-Man
Hardware/Software: Modified NovaTurn with Yaskawa AC Servos +-10V, PathPilot running on a GizmoSphere 1 with Ibob2 PCIE interface that I designed. Denford Triac to be modified with AC Servos.
Post by Iron-Man » Mon 07 Mar , 2011 22:40 pm
angel-tech wrote:no probs, it'll take me a while to get it apart.
Thanks, angel-tech.
Iron-Man
angel-tech
4 Quatros
3 Oracs
2 Easiturn atc
Mach 3
Post by angel-tech » Tue 08 Mar , 2011 2:00 am
all apart, ask away.
Post by Steve » Tue 08 Mar , 2011 11:42 am
I have printed the BOM for the TP121 Turret.
I have highlighted the parts we have in stock in Green. We only have one or two of each of the bits which are for spares use.
I would assume you will be able to locate the electrical parts elswhere but may be interested in the Main Shaft worm shaft and worm gear.
I have also priced thes components.
I will see if I can add the drawings for the toolpost body and tool turret.
turret TP121 parts list.pdf
(55.98 KiB) Downloaded 1207 times
Post by Steve » Tue 08 Mar , 2011 11:47 am
Here is the drawing for the turret assembly, the turret body and the tool plate.
Tp121.pdf
(128.32 KiB) Downloaded 1235 times
Tp121_02.pdf
(171.55 KiB) Downloaded 1308 times
Tp121_01.pdf
(185.25 KiB) Downloaded 6218 times
Iron-Man
Post by Iron-Man » Tue 08 Mar , 2011 14:38 pm
Steve wrote:Here is the drawing for the turret assembly, the turret body and the tool plate.
Thanks for all the information :D .
Iron-Man
JohnHaine
Post by JohnHaine » Sun 27 Nov , 2011 15:20 pm
Iron Man -
Which Harting connector was it in the end please?
I have a Novamill which seems to use the same type but no control box so am going to use Mach 3. I don't want to start rewiring the mill so need to find a connector.
Admin, please could you confirm that the Novamill and Novaturn use the same type?
Thanks,
John.
Iron-Man
Post by Iron-Man » Sun 27 Nov , 2011 17:07 pm
JohnHaine wrote:Iron Man -
Thanks,
John.
I have not purchased it. I lost some of my research on an older computer and have not recovered it yet. I believe that it is a Han® 42 DD connector. https://www.harting.co.uk/imperia/md/con ... n_d_dd.pdf
See page 13 of the above document. Also, see this file viewtopic.php?f=42&t=2629 document NVT-D11E.pdf.
Hope this helps,
Iron-Man
JohnHaine
Post by JohnHaine » Mon 28 Nov , 2011 14:58 pm
Great, thanks for your help.
John
