viceroy lathe feed problems
just bought this viceroy lathe and im quite new to these older machines had a chester modern machine previous the problem i have is with the auto feed gear it seems something is missing or broken as it wont work ive posted pics( i hope ) to see if anyone can shed me some light on the fault .
ive converted it to single phase and hoping to keep it for a long time and clean and service it .it cost me £180 and hope ive not wasted my money with the feed fault as it is
cheers gaz
tates 032.JPG (131.3 KiB) Viewed 5231 times
tates 030.JPG (90.96 KiB) Viewed 5231 times
tates 035.JPG (63.01 KiB) Viewed 5231 times
Re: viceroy lathe feed problems
I'm a bit mystified ?
In what way is it malfunctioning ?
Does the leadscrew revolve when the lathe is running and the gears are engaged ?
If you grab the leadscrew you should be able to turn it by hand and all the gears should turn.
(obviously not with the tumbler drive engaged though).
I think there is a little shearpin connecting the leadscrew to the rest of the works.
Cheers,
LesT
LesT wrote:I'm a bit mystified ?
Cheers,
LesT
the lead screw didnt turn when gears engaged
took the leadsrew out and had a sheer pin fitted enginer said looked as if someone has had a go at repairing the fault without sucess up and running now also striped and cleaned thanks for help cheers gaz
