Creating .STL files from free version of Google SketchUp
Google SketchUp is a free 3D modelling tool, and there is a plugin available which will allow you to create .STL 3D model files suitable for loading into Denford QuickCAM 3D to make cutter paths from.
Download and install SketchUp from here: https://sketchup.google.com/download/
Then install the plugin available here: https://www.guitar-list.com/download-sof ... dxf-or-stl
(at time of writing, the file was skp_to_dxf.rb)
Save the file into the SketchUp plugin directory which is normallly here: C:\Program Files\Google\Google SketchUp 7\Plugins
Then....
Re: Creating .STL files from free version of Google SketchUp
... Run SketchUp and have a browse through the masses of 3D models...
... select (highlight) the model and goto the Tools menu, select Export to DXF or STL and choose the .STL option when asked and save the file...
... load up the .stl file in QuickCAM 3D or QuickCAM Pro and create a CNC toolpath 8)
OMG!!
It is a wonderful idea. Now I need to find a block of wood to make that happen. lol..
Best regards,
David Fhu
“Dream as if you'll live forever, live as if you'll die today.” - James Dean
