No homing
Crakkers
No homing
Post by Crakkers » Wed 28 Apr , 2010 11:17 am
VL300 no longer homes when switching on and completing work. In fact machine now does not work. The homing is simulated within the laser software but not physically home, ie lower and raise the bed to the prescribed height.
I have also noticed that within the laser software that has green amber and red leds, only the amber and red flash. What does this indicate?
Re: No homing
Post by bradders » Wed 28 Apr , 2010 14:20 pm
Hi there,
1. Does the Laser software connect to the laser OK ?
2. Is the fan running on the Laser ?
3. Check out the 2 fuses are OK, in the little pull out drawer underneath the kettle plug on the rear of the Laser.
4. Is there 240V on the Kettle plug ?
Crakkers
Re: No homing
Post by Crakkers » Thu 29 Apr , 2010 12:16 pm
ok, all fixed, dont have a reason, but unplugged and replugged everything and then bingo!
ps, what do the green , yellow and red lights mean?
Re: No homing
Post by bradders » Thu 29 Apr , 2010 12:18 pm
I'm glad you are up and running.
Green - Compressor or Extraction fan should be running
Amber Flashing - USB communications
Red - Door open / closed
Re: No homing
Post by Martin » Thu 29 Apr , 2010 20:06 pm
Green - Compress or Extraction far should be running
Bradders are you sure the above is correct?
Re: No homing
Post by bradders » Fri 30 Apr , 2010 7:25 am
I presumed he meant the LED's on the Versa Laser USB communications boards, i.e. the extraction fan and compressor unit. Plus the RED led on the button pad
