TRIAC PC _DOS ERROR COMMUNICATION
pant
Re: TRIAC PC _DOS ERROR COMMUNICATION
Post by pant » Sat 05 Nov , 2011 10:53 am
These i put in fanucm.opt(.go) or in flstep.opt (.go) ???
the same .opt & .go text do i use with the desktop ????
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
Post by Martin » Sun 06 Nov , 2011 9:52 am
Yes.
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
FANUC_SDEVICE machine
UTILS_MENU_1 Dos Access
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
SLAVE_CONTOURFEED 0.15
SLAVE_CONTOURANGLE 0.15
XIO 1
ATC 0
Fanucmd.opt
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
FANUCMD.APP
pant
Post by pant » Mon 07 Nov , 2011 12:46 pm
dir martin
I have done that you write to me but....--->
fanucmd.opt
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
HIGHFEED 2500
HIGHFEEDZ 1500
MAXCONTOUR 90
XIO 1
ATC 0
Fanucmd.go
IBM.RS2 2
$3F8 3 COM1
$2F8 3 MACHINE
DENFORD1.KBD 1
18.2 $3F8 4
VGA.CRT 0
it works with FLSTEP.APP ---> instead of FANUCMD.APP
BUT with FLSTEP as i have wrote before i have lathe software in mill machine .
i can't have the control from tutor desk except cooling on ,cooling off.
if i download HEIDEN from 5 1/2" disks in PC and run heiden , the program runs but i dont have control of the machine.
Is there FLESTEP FOR MILL???? OR FLESTP.APP FOR MILL???
Post by Martin » Mon 07 Nov , 2011 17:37 pm
No Flstep is turning software only.
Have you copied the "Drivers 2" directory in to the working directory?
pant
Post by pant » Thu 10 Nov , 2011 5:39 am
Finally it worked. I am very satisfied and happy
I suspect that the problem they was the cards. I removed and put the all cards, afterwards all via yeast it worked
Your contribution they was despite very auxiliary. I have read a lot in my forum for problem and I acquired a lot of interesting things that me helped I reach in the result.
Thanks particularly Martin and denford Admin and Graham Bradley for his interest and the advices.
Many thanks
Pantemis Gregori
Teacher high school
Lesvos
Greece
Post by Denford Admin » Thu 10 Nov , 2011 9:58 am
Great news - glad it's working again 8)
Did you get it to run from fanucmd ?
What did you need to do to create the correct files ?
Was it just changes to the .go and .opt files or something else ?
pant
Post by pant » Fri 11 Nov , 2011 21:17 pm
Thank you
Because i'm abord i'll tell you on Monday
pant
Post by pant » Mon 14 Nov , 2011 21:51 pm
The programme that works fine for triac pc with dos was
Fanucmd.go
NARROWSIMBOX 0
SHOWTOOL 0
USE3D 0
UTILS_GO_1 dos
TOOLORIENT 0
HIGHSPINDLE 4000
Fanucmd.opt
IBM.RS2 2
$3F8 4 COM1
$3F8 4 MACHINE
DENFORD1.KBD 1
18.2 $2F8 3
VGA.CRT 0
FANUCMD.APP
Post by Denford Admin » Tue 15 Nov , 2011 9:46 am
Thanks for letting us know :)
Nick
Post by Nick » Sat 17 Nov , 2018 19:19 pm
Dear Sirs
I'm also from Greece (Evia island)) and I have more or less the same problem with a Denford triac pc. The machine is working now with a 286 pc and 5 1/4 floppy discs. I have to load with a floppy first DOS and with an other floppy fanucmd...
I'm trying to change the pc, with a pentium windows XP (service pack 3) that i found spare in my new school, the only one with two male serial 9 pin D ports,
but I took as a result
What do you suggest me to do?
Thank you in advanced
Nikos
pant
Post by pant » Sun 18 Nov , 2018 16:40 pm
dir nikos
put a hard disk with windows 95
my email is gpantemis@gmail.com for more informations
greg
