VL300 Connection to PC & Firmware
Crakkers
Post by Crakkers » Tue 02 Oct , 2007 12:24 pm
Installed versa laser on standalone PC. everytime I switch PC on it states new hardware found and looks for firmware. Laser extraction is constantly switched on - noisy! but can not control machine via PC.
Please advise exactly what software I need to download. Original disks are lost!!!
Op system is XP
Post by bradders » Tue 02 Oct , 2007 14:49 pm
Crakkers
Post by Crakkers » Tue 02 Oct , 2007 20:58 pm
does not answer the question.
why does new hardware found come on everytime I boot PC up, even though software has been installed and reinstalled many times, as per your instructions?
Post by Martin » Wed 03 Oct , 2007 19:52 pm
It sounds like you have a problem on one of the USB devices.
Try looking at the USB devices in device manager & check that they are all installed correctly. If one shows a error then try to update the device.
Post by Steve » Thu 04 Oct , 2007 9:01 am
It is probably somthing to do with access rights on the computer.
Have you tried logging on as an administrator then loading the laser drivers. It may be as a standard user the changes you are making each time are not being saved.
ULS Service
Post by ULS Service » Thu 04 Oct , 2007 10:50 am
it looks like the usb board from your pc, does search it every time, because otheriwse there will be no reason, why it alswys shows you that a new device was found.
Maybe try to connectg the machine to another usb board on your pc or try to upgrade your usb board drivers.
regards
Bernhard
best regards
Bernhard
