unknown error messages
Large519
Hardware/Software: Denford Triac PNC3
FeatureCam - CADCAM
Delcam Powershape
Post by Large519 » Fri 23 May , 2014 23:33 pm
Hi, I am having issues connecting pc to machine (microrouter pro), I get the following error messages.
Drive reports incorrect toggle bit.????
And
Must use a setxxxlink function.????
Can anyone help and advise what to do??
Thankyou
Re: unknown error messages
Post by Martin » Sat 24 May , 2014 0:08 am
What is the colour of the 7 segment LED in the electrical panel?
If it is not red then try to connect using EasyUgrader.
Large519
FeatureCam - CADCAM
Delcam Powershape
Post by Large519 » Sat 24 May , 2014 0:26 am
Hi it was green.
I have just tried the easy up grader, but still get error message
Drive reports incorrect toggle bit.....
Have I got baud rate, bit rate etc setup wrong,??
Do you know what these should be set at?
Large519
FeatureCam - CADCAM
Delcam Powershape
Post by Large519 » Sun 25 May , 2014 1:08 am
After much investigation it would appear to be an issue with the pc, I was originally running mach3 on the system with my other router, but now I was planning to run a pro router on the same system using vr milling, a windows optimization check list I had done recommended by mach clearly has issues with other programmes.
