Hi All, Im new to this site
Just wondering has anyone run one of thease on a phase converter is so witch one and is it o.k.
Help needed on easiturn
- Triac whizz
Well.........
The only bit that needs 3ph is the motor control - if you're good with wiring diags you can find the relevant offenders and change the inverter for a single phase in 3ph 230v out and you're sorted
Oh and change the wiring for the motor to suit 230v
easy eh?unless it's a Fanuc or hiedenhein control.... (sod the spellin')
www.la-coterie.com
www.la-coterie.com
