FSSB Error?
jamesgates1000
Serial number - H00913.
Serial number - 70826B.
FSSB Error?
Post by jamesgates1000 » Mon 07 Oct , 2024 13:34 pm
Hi all,
I have a problem with my Cyclone. Hasn't been used for a while and batteries went flat.
I replaced them while the machine was on but it has lost its Z return position and also I am getting some other strange errors.
I get 5138 FSSB:Error when i first turn the machine on.
After hitting the green button on the front this error clears and I get...
300 APC alarm x axis need ZRN
300 APC alarm z axis need ZRN
301 APC alarm x axis communication
301 APC alarm z axis communication
Does anyone know how I can clear these errors? At the moment I cannot even jog the axis
Re: FSSB Error?
Post by Steve » Mon 07 Oct , 2024 15:11 pm
Have you got a backup of the machien parameters?
When the battery went flat you may have lost all the parameters which could include the drive paramiters.
Re: FSSB Error?
Post by Martin » Tue 15 Oct , 2024 8:15 am
If the machine is fitted with absolute pulse encoders on the axis motors it may be that the batteries on the drive are low & then you will need to home both axis.
Fanuc 21i Reference Procedure Without Reference Switches.docx
(23.34 KiB) Downloaded 411 times
jamesgates1000
Re: FSSB Error?
Post by jamesgates1000 » Tue 29 Oct , 2024 9:35 am
All the parameters seem to be there.
I does look like it has to be referenced, but I think it is stuck on the Z+ limit.
How can I move it off the limit?
