How to change the tooling and offset file location - v5
Post by Denford Admin » Mon 21 May , 2007 13:37 pm
How do I change the location of the alloffsets.mof file from its default location in VR Milling version v5 ?
Some networks are restricted and will not allow the default file to be edited...
Post by Denford Admin » Mon 21 May , 2007 13:40 pm
Open the work offset editor - the Offsets / Tooling menu should now appear on the top menu bar as shown.
Select the option "Save As..." and save the offsets file to a location on the network, which you have read / write permissions
Post by Denford Admin » Mon 21 May , 2007 13:43 pm
Now, to make VR Milling use this file, select the "Advanced" menu option and click "Load All" which will have now appeared....
Now choose the .MOF file you saved previously
