Viceroy TDS 6WL Wood Turning Lathe Manual & Drawings
- bradders
Viceroy-TDS-6WL-Wood-Turning-Lathe.pdf
- Viceroy-TDS-6WL-Wood-Turning-Lathe.pdf
- (1.99 MiB) Downloaded 2623 times
Re: Viceroy-TDS-6WL-Wood-Turning-Lathe.pdf
Hi there, i've just bought one of these lathes and the pdf of the headstock was handy as i need to make a headstock shaft as its missing. I don't surppose theres another drawing of the main shaft with measurements and how its all put together. I have the bearings,couple of ring nuts and bearing caps. I've got the thread sizes and know its a 3mt but theres many things i don't know but hope to find out. Can anybody help???
I can guess alot of it but it would be good to keep it original.
There are some other wood lathe drawings on here:
viewtopic.php?f=50&p=5232
viewtopic.php?f=50&t=1557
And here are the only WL drawing scans I can find:
http://www.denfordata.com/downloads/for ... -Scans.pdf
Thanks. Its helped me out no end.
Im sure Ive got an inboard 4 inch face plate somewhere if you need it??
Gary
Gary
