VR Milling Ver 5 USB drivers
After installing the Nextmove card into the machine, and plugging it into the USB. I Thought that the PC would auto detect that it has some sort of USB device plugged into it (XP) but this is not the case.
Also when I try to set up the real machine using VR milling I get an access violation error this is when running through your tutorial or whenever I press the machine button.
Search VR Milling Ver 5 CD for the USB folder and install the Baldor USB drivers
You need to get the Baldor USB device to appear in device manager first or power not to Nextmove card properly - Check the green 7 segment display is illuminated, or its not XP/2000 operating system
