The IMO Jaguar (Commander?) Inverter has given up the ghost. I tried replacing the internal mains fuse but it just blew again. The two Inverters that I have on other machines and all others that I have seen use seperate inputs for fwd and rev but the Jaguar only uses 1. Does anyone have a wiring diagram for the drive control circuit?
    				    			Have just put this up:
viewtopic.php?p=2765
I think the drive will run FWD by default, unless you make the REVERSE input
