The machine looks like its done little work.
The origional drives and power supply are still ok'ish.
I am probably going to use mach3 on it.But for the time being i am useing cnc zeus to do testing.
The strange problem i am having is if i place any one of the three axis drives in there relative slot, that axis works fine. If i then add any of the other drives the motors whine and control of the motors is unpredictable,this is also the same if i add the third drive. Ihave checked the drive and the logic voltage and both seem fine . Please has anyone got any ideas what might be causing this as all the drives work individualy. The drives are 2 x sd2 1 x sd3.
