Cable Diagrams
As i am not fully up to speed with wiring diagrams, could some one tell me on the 'IBM to TRIAC' drawing below.
What the 'loop' symbol from pin 2 on the 7 pin connector stands for.
Roy 8)
Roy,
Its the interwoven metal screen wire that surrounds the other plastic coated cables. Therefore you want "Screened cable" to make up the final cable
There was a bit of a discussion on this cable here:
viewtopic.php?t=596
Thanks, I was thinking that possibly could be the case. But best to check with you experts!
Roy
Hi I have got some cable which has a foil shield, will this do the job?
Roy
