Problems installing LaserCAM 2D
I am having problems problems installing LaserCAM 2D, i have downloaded version 1.4 from the Denford web site and tried in on 4 of my colleagues PC's with the same result. See the attacled link
https://www.shelleycollege.org/james/denford.htm
The software looks like it is failing to load up something at the start - could be an activex control, or maybe the OpenGL graphics drivers.
Try:
Reduce hardware acceleration to none.
Install and run as the same Administrator
When you say you have tried on various other PC's - are they all the same type ? and connected to a secured network ?
Can you try it at home, ie, on a regular XP PC ?
We have never had a problem running the software here or at other schools, so it must be something to do with access permissions, or the hardware / drivers on the PC's
