Denford Triac with ATC
Want to take of the Automatic Tool Changer and the Pnumatics off my Triac mill. How do I get past the start up datum procedure. At present the ATC needs to be part of the start up sequence. A signal goes to the Main board electronics that the ATC is ready before the slides start datuming.
Jim the Fish
Without knowing anything about the older machines, I would guess you can fool the control board into thinking the ATC is there, maybe by linking a signal high or low.
daveimurray may know more - I think he has retrofitted similar equipment, so would know about the signals used - it may not be a simple case of pulling up or down a signal.
mrmagoo may also be able to tell us if there are any parameters / options which would turn off the toolchanger.
for a start the air pressure switch will need linking out - I know it won't reference without the air holding the ram up (there's probably another switch there)
But as to what happens when you come to a toolchange.....?
www.la-coterie.com
