VR Milling 2 - general FAQ's
Q. The part is cutting at the incorrect depth.Usually the problem originates from the workpiece offset file not being set correctly.
Go back and reset the offsets. Also, check the depth of cut in the CNC program.
Q. The part begins cutting at the wrong location.
The X and/or Y offset values may be wrong. Reset the offsets.
Q. When running a 3D simulation, the cutting path does not appear.Sometimes if the cutting depth is very shallow, the part will not immediately display thecutter path.
You will need to rotate the 3D view of the part.
To do this, hold down the left mouse button in the 3D window while moving the mouse.*
This will rotate the part.Release the mouse button to see the new view.
(*VR Milling version 2 only)
