QuickTURN2D v1.38 released 8th November 2024
v1.38 - The maximum diameter and length of the billet is 200mm by default. However on the machine options page, the maximum values of both dimensions can be set by the user.
Quickturn should no longer ask for admin rights to run.
Find the latest version here:
https://www.denfordata.com/downloads/Qu ... _v1.38.zip
Re: QuickTURN2D v1.38 released 8th November 2024
I note that this release is dated tomorrow!
I removed my existing version v1.35 and attempted to install version v1.38 on a Windows 11 pro machine.
However I get an error message as per the attached screen shot.
Reloading v1.35 works OK. I have a licence
Max.
Problem solved. Installation was being blocked by Norton Anti-Virus although it didn't actually tell me that. I had to exclude a number of files in Norton AV to stop them being blocked.
Windows Control Panel/Settings reports the software level as being 1.37.0057, but on opening the app it shows it as 1.38.9078.33695.
Hi Max. I've checked the installation here and it passes a virus check with both Windows and also the Sophos software that we use, so it must be a false alert.
The installation version number has also been updated to 1.38.
