Easy Upgrader 2
With the change of control card on our current range of machines, some of the support for the Nextmove USB control cards will be moved over to this forum.
I have created the attached document to support the use of the Easy Upgrader 2 software.
This can be used to:
Change the Firmware version
Change the Machine Type
Change the serial number of the machine
Check IO and Encoder function
This software is very useful for fault finding or if control cards are swapped between different machines. The installation is included in the downloads for VR Milling V5 and VR Turning V1.
Thankyou
Mitch
Easy Upgrader 2.pdf
(740.08 KiB) Downloaded 937 times
