How to setup a Turn270PRO tooling and workshift
All info relating to the Denford Turn270 and NewTurn270 CNC lathes
Post by Steve » Wed 22 Mar , 2023 11:35 am
Attached is a Powerpoint download showing how to configure the software and set offsets for a Turn270PRO.
This is a video record of setting up the machines while holding a phone in one hand so a bit shakey but good content
Videos on how to setup Lathe tooling
https://www.denfordata.com/downloads/Se ... 270Pro.zip
DavidB
Re: How to setup a Turn270PRO tooling and workshift
Post by DavidB » Thu 23 Mar , 2023 4:39 am
The file seems to be incomplete or corrupt as initial download indicates 1.4 Gb but only about 60Mb downloads before completion and the resulting ZIP file is said to be invalid.
Post by Steve » Thu 23 Mar , 2023 17:00 pm
Tested the download and it worked for me.
DavidB
Post by DavidB » Thu 23 Mar , 2023 19:03 pm
Steve,
Can you post the ZIP file size as I downloaded it again and no joy. The file fails to unzip on Win10 with a 'failed to create file or directory' error and similar on an iMac. My Ubuntu Linux machine gives and 'unexpected end of file' error. Never had any issues downloading files from the forum before but if I know the precise file size I can check if something is going wrong with the download.
DavidB
Post by DavidB » Fri 24 Mar , 2023 1:04 am
Steve,
I got it in the end and it is 1.5Gb which was the issue. It seems large transfers such as that can often be problematic and may fail due to network issues. With Firefox I was getting about 64Mb consistently before it failed, a neighbour got about 325Mb with Windows before it dropped the connection. In the end I used 'curl -C - -O https://www.denfordata.com/downloads/Se ... 270Pro.zip' in a terminal and it came down OK, previously tried without the '-C -' and it got to about 710Mb before dropping. The '-C -' option tells it to continue where it left off. I don't know if there's an equivalent command for the Windows prompt.
Post by Steve » Tue 28 Mar , 2023 12:57 pm
Thanks for letting me know. I realised its a large file but the order of setting things made it worth storing this way.
