oiler
will it be ok to use motor oil in the lubricator on my triac?
the reason being is I dont want to buy a 5 gallon drum of the correct oil!
I have read that its fine or if I wanted thinner I suppose I could use 3in1
Any views?
nick some hydraulic oil out of a jcb ;) thats what I use, ok so its not stolen
www.la-coterie.com
Re: oiler
comet wrote:Hi,
Any views?
An old thread, I know, but if anyone else is searching for oil info:
68 grade 'Way Lube', or 'Slideway Oil' is what you want. It has a special tacky additive that helps it stick to and stay on the slides for longer. If you can't get proper slideway oil, a good substitute is chainsaw oil, which has the same additive to stop it being flung off the chain. Chainsaw oil is sold in most garden centres.
Mr Magoo, Martin, Steve
