QuickTURN2D v1.34 released 3rd August 2021
v1.34 - The graphics library that runs the simulations has been updated and edited to accomodate all types of graphics card. Modern laptop PCs are often shipped without the correct openGL libary. That won't be an issue anymore, and QuickTurn will always be able to use the hardware to run the simulaition without raising an access violation error.
There was also a bug where the displayed angle of a line was being converted from metric mm to imperial inches. It will now correctly show the degrees of the line from the horizontal x=1,y=0.
Find the latest version here:
https://www.denfordata.com/downloads/Qui ... _v1.34.zip
- Hardware/Software: quick turn 2D
denford micro turn pro in schools
Re: QuickTURN2D v1.34 released 3rd August 2021
Good morning,
as you can see, i try to create a quarter circle with r=10. The problem is that the center of the circle is not right. I has to be (0,-5) and somehow it autocompletes itself in this nonesense. Every time i try to change the center coordinated manually, all the other parametres change randomly. Please help me to do it right !
Thank you in advance.
Image link https://prnt.sc/1xacfxu
