There seems to be some spongyness in the movement, no play in the Z axis, i.e, the gib strips are adjusted ok and the lead screw has not axis play, so it only leaves the nut, which seems to have ball bearings in it made of rubber as I can get 10 thou movement... but not a clonk clonk sort of movement, just sort of "flexes"
So to my question(s) Are these nuts adjustable? I don't want to take it to bits yet
and merry xmas (or should that be seasontide?) to denford users & manufacturers
