Orac software for older machines
I wanted to share this with everyone who ownes an older (1984 and older) Orac lathe. This is the offline editor and loader program that allows you to connect a computer to the RS323 port. It allows you to program and upload your programs to your lathe. I hope this helps someone out.
Be sure to read the install instructions included with the zip file.
Provided as is as I haven't had a chance to play with it.
Adam
ORAC.zip
1984 and older Orac software
(141.49 KiB) Downloaded 1113 times
Orac TDS/O/R/CNC
S/N 32155
I'm guessing this is an image of a DOS booting floppy disk ?
There is an autoexec.bat on there which sets up the com port and some other things before running orac.com
Maybe worth bearing in mind if you intend running it from a newer OS
Cheers for the upload :D
