If an attempt is made to add line numbers to a part program, having blank lines, the entire edit window is deleted.
ie:
Open a .fnl file.
Click Editor.
Click Modify.
Click Line numbering.
Click OK
The contents of the edit window are deleted.
It took me a while to realise what was causing the problem. Any chance of a fix in the next release?
Thanks, Max.
Thanks for the notification. I can recreate the problem here so we should be able to resolve it in the next release.
Hi. There is a new version, 1.53, which fixes the issue. Blank lines are left in and not given a line number, and it doesn't wipe out the existing gcode.
https://www.denfordata.com/bb/viewtopic.php?f=8&t=5977
I've loaded the new software and line numbering now works correctly.
Thanks for the fix.
    				    			Thanks for the fix.
