Triac spindle motor indentification
Hi, I got a Triac and it is fitted with a larger spindle motor. It was also supplied with the original motor. But it has no identification or make on it whatsoever. Only the serial 4787. I was told it was 1hp
Anyone? - thanks
Re: Triac spindle motor indentification
This would have been the SEM motor MT30U4-36 Denford part no BI00307G
We now use a different motor with a slightly different shaft size but otherwise the same. BI00307GM
Brilliant - thank you
Mr Magoo, Martin, Steve
