Wanted: Denford Orac, Microturn or similar
I am looking for a Denford Orac or a Denford Mircoturn as a first CNC lathe as I would like to turn some parts in aluminium alloy. (The parts will not exceed 60mm length and diameter.)
I have been working for some months now on Fusion360 and am keen to start working in metal having completed some prototyping of the parts I need on a 3D printer and have created and simulated my turning tool paths.
I understand that the Orac machine is legacy and would need converting to Mach3 or similar but I have the time to do this as I am currently unemployed but obviously I do not have the money for a new small CNC machine.
I would also be interested in a Denford Microturn for an appropriate amount and already have a price from Denford for a new software licence.
I can travel for the right machine also as I am keen to get started.
Peter
Re: Wanted: Denford Orac, Microturn or similar
look out for the starturn and novaturn too. Might still be some schools selling them off.
Thanks for the advice. I will keep a look out. 8)
I have a very nice Mirac PC that i'm looking to sell.
all the hard work done, its wiring has been converted to run either Mach3 or UCCNC - just needs the ATC building back up as it was full of solid grease.
Software would need to be configured for whichever control you wanted to use but options for either are there.
UC300ETH-MAX Controller from CNCroom.com
Two new inverters, one for spindle & one for tool post
New British spindle encoder 360ppm
Pneumatic Chuck & Pneumatic guards open/close of buttons now rather than M codes
Its hardly done any work and inside the machine is in very good condition - outside it has some wear and marks but i was just going to give it a freshen up.
all wiring has been traced from original diagrams and all matched by original numbers where possible so its easy to see what's going on
drop me a message with you email and I'll fire some pictures across
