Hello, I am resurrecting an Orac using PlanetCNC control. I am trying to get the original map light up and running. It connects to a transformer and what looks like a relay - labelled 'keyswitch' -with 8 connections on it, it has a small coil, and a spring inside a transparent case. I am not sure how to wire this up for power. Should mains voltage go to the 'keyswitch' and if so how is it wired? There are no markings on the components. I presume the actual light is 12V?
Any advice is really appreciated. Andy
