My mirac pc pauses between each block of code.
For example, if the program was to read:
N010 G01 X15 Z0
N015 G01 X15 Z-5
N020 G01 X15 Z-20
Then the feed would pause for a considerable time at Z-5 leaving a gouge in the workpiece as it chatters.
( I know you would not normally use such a code as above but it's just for illustration)
I have seen this issue before in milling, where the solution was to use G64. But the miracle doesn't recognise it.
I believe it is a denstep board but can't be sure, I'm not able to get access to the box to check.
Anyone come across this before?
What version of software are you using?
Have you got turbo turned on on the control panel?
Software is VR turning v1.49.0.0
Sorry, I'm new to vr turning! you'll have to point me in the direction of the control panel...
Do you mean machine parameters? There's a check box for high speed cutting under "machine capability"?
Duncan
Duncan
www.clydepencompany.com
