						Feed rates?
						Posted: Sun 12 Jan , 2020 12:06 pm
						by andy_con
						What sort of feed rates are people using on the micro router?
I wonder if I'm going a bit slow?
6.3mm router bit I'm running at 500mm/m on mdf with a 2mm DOC
						Re: Feed rates?
						Posted: Mon 13 Jan , 2020 8:49 am
						We recommend a feed of 1000, spindle speed 23000 & depth of cut 100% of tool diameter.
						Re: Feed rates?
						Posted: Mon 13 Jan , 2020 14:58 pm
						by andy_con
						so if Im using a 6.3mm router bit, you recommend 6.3mm DOC @ 1000mm/m?
wow
						Re: Feed rates?
						Posted: Mon 13 Jan , 2020 15:37 pm
						Yes that's what we use.
If you want you could lower the depth of cut & increase the federate.
						Re: Feed rates?
						Posted: Mon 13 Jan , 2020 16:58 pm
						by andy_con
						and a denford microrouter can handle that?
						Re: Feed rates?
						Posted: Mon 13 Jan , 2020 19:47 pm
						by TDIPower
						I run it all the time on the 2 machines at work and mine at home,  your ears are your friend... if it sound rough dial it back on the over ride.  So if you are doing a plunge/slot cut then I might dial it back a little then when it is up or down milling it will be fine on 50% step over
