MACH 3 Limit switchs
Post by Chestnut84 »
So since early this year ive been using the novamill with my steppers wired through the 96pin connector and a 25pin parallel port header via mach 3. The spindle is hard wired with a potentiometer for speed adjustment. (id like to addess this at some point too) in my latest research ive been struggling to come up with a solid solution for not having the limit switchs wired up. Id really like to be able to reference the machine and set up the travel parameters.The most useful info i found was from someone using a breakout board. If anyone know how to get the switches working with what i have that would be great. Thanks to all of you who stay active and use you free time to help people on here.
Martin, Steve, Mr Magoo
