VR Turning and serial port.
MAX THE MILLER
Hardware/Software: Denford Triac PC. VR Milling 5.51.0.616
Post by MAX THE MILLER » Wed 24 Apr , 2019 22:15 pm
Is there a version of VR Turning that will work via a serial (RS232) port?
I might be able to justify purchasing a licence for VR Turning, but upgrading the serial card to USB is out of the question.
Thanks, Max.
Re: VR Turning and serial port.
Post by Martin » Thu 25 Apr , 2019 8:10 am
Hi Max
VR Turning will work on either RS232 or USB depending on settings & as long as the machine has a SmartStep or DenStep control with a VR Eprom
fitted(2.0 Beta or 2.1)
Before that we used Dos software & a Dos eprom.
MAX THE MILLER
Post by MAX THE MILLER » Thu 25 Apr , 2019 10:06 am
The control card is I believe a Eurostep and is pictured in this thread:-
viewtopic.php?f=40&t=5620&p=22582&hilit=eurostep#p22582
I have a V2.1 EPROM. Can this be fitted to the Eurostep control card?
Thanks, Max.
Post by Martin » Thu 25 Apr , 2019 11:42 am
Hi Max
Yes you can replace it with the 2.1 EPROOM & then connect using VR Turning.
MAX THE MILLER
Post by MAX THE MILLER » Thu 25 Apr , 2019 11:57 am
Thanks Martin.
I'll give it a try.
Max.
