Pause opening or closing door
I have a problem opening and closing the door. When I send the command M38 and M39 there is a delay to make the function. You need to press the Esc key to continue opening or closing the door, as it remains paused. I do not know if it is the PC communication with the CNC. I change to the PC but the problem continues. Any ideas.
I have a VMC 1300 Pro.
Thank you for the help.
