Drilling holes
Hello,
On the Denford compact 1000 pro, is it possible to change the router head for a drill bit to drill holes - for example, I am currently doing a set of wooden backers for some brass plaques which have 4 screws at the corners - is it possible to drill the pilot holes for these whilst routing out the wooden backers?
thanks
Jon
Re: Drilling holes
We can offer quick change tool holders for the routers which would let you change to a different tool in the program. You should be able to peck drill holes as part of the program.
Re: Drilling holes
If you only have the 1/4 collet you can get 1/4 to 1/8th inserts you could then use the 1/8th shanked drills of various drilling dia. You can get them with collars so they always fit in the collet to same depth for tool changes (set your offsets in tooling library).
I frequently 'drill' with single sided router bits for less than 1/4 or 2sided for 1/4 for above, the problem with 'plunging' router bits is they don't always have a cutting edge to the centre on the bottom face. Peck drilling is the best way
Re: Drilling holes
Need file of quick change tool holders for the routers facing issue to fix the drill bitt.
