Hashed up Cyclone
Hi all,
Could do with some help please!
Have got a cyclone P with a fanuc 0T system that someone has obliterated in the past by removing the turret and replacing it with a single tool.
Why they would do that, god only knows!
Since it's purchase, the system battery failed which resulted in total loss off parameters.
I have used the site to recover the lathe somewhat, using the parameters and options, but need more to get the machine to function properly with a recently purchased 8 station turret.
I really would appreciate it if someone, who has a 'P' w/ 0T control could copy their diags/pc parameters as i think this is the fix.
Here's hoping!
Lionel
Re: Hashed up Cyclone
If you have the serial number I may be able to find the original Parameters & Diagnostics.
I will try to find out but couldn't find the manufacturer's plate.
Is it inside the cabinet?
If you have a transformer box it will be on the side.
Serial no.29100E
No. Of control (if used) 9013691
Here's hoping!
