Feed Rate
Compact 1000 here. When I'm ready to mill an FI car, the feed indicates a RED X on the white glove. The router turns on but does not move.??? Any advice? Thank you.
Re: Feed Rate
You should have a feedrate override knob above the emergency stop which should be set to 100% ( Between 2 & 3 o'clock).
Re: Feed Rate
Thanks for your advice. I set the feed rate to 100% but still have the Red X. I tried jogging the x, y, z axis. The router does not move, but the axis counters do.
