I HAVE LOOKED AT A DENFORD CYCLONE LATHE FOR SALE BUT I HAVE BEEN TOLD IT SHOULD HAVE A POWER SUPPLY BOX THAT YOU CONNECT TO 3-PHASE 415V AND THEN PLUGS INTO THE MACHINE WITH TWO BIG CONNECTORS APPROX 8 PINS EACH. WHAT DOES THIS BOX CONTAIN AND IS IT POSSIBLE TO OBTAIN A REPLACEMENT. THE MACHINE IS FITTED WITH FANUC CONTROL.
Probably all the expensive Fanuc cards and contactors etc - very expensive! The only use it will have will be a retrofit.
www.la-coterie.com
www.la-coterie.com
The box you are talking about should have a couple of transformers, a 24volt DC power supply & several fuses & circuit breakers. It was only the early machines that were built like that though. If the two 16 way plugs are fitted the transformer box is needed. It would be a trauma to reproduce the box now.
