Hi;
I need a help. I have got a TRIAC FANUC ATC, with the following characteristics, Model: TRIAC FANUC
Serial NO: EO4157
Despatach : November 1992
Export NO 4157
Serial NO of Electronics: 2050745
INSIDE ELECTRIC CABIN
Denford
FANUC Series 0-MC
Type A02B-0098-B511 N0. 2050745 Date 1992-05
Serial No. 2050745,
Memory board A16B-1212-0210/12C
I lost all the parameters, when I tried to replace from the backup, I realized that there are not the 900´s parameters.
Someone can send me those parameters.
I´m in a very big trouble, because I can´t carry on doing my tasks.
Many thanks.
All the best for you.
Fernando Guedes email: fernando.guedes@inesctec.pt
TRIAC FANUC ATC 900´s parameters
- Hardware/Software: Software MasterCam
CIM- Includes - CICLONE FANUC LATHE, TRIAC FANUC ATC, CMM Machine, Conveyor, AS/RS, Slide, 2 Mitshubishi Robots.
Re: TRIAC FANUC ATC 900´s parameters
I can't find the folder belonging to your machine but looking through similar machines the 900 parameters all seem to be the same.
Don't forget you will also need to insert the relevant 450 diagnostics & set 453 bit 0 to a 1.
- TriacFanuc.pdf
- (509.41 KiB) Downloaded 591 times
