Nextmove No Firmware
If your NextMove controller card has lost its firmware it will no longer communicate with the Denford software or Easy Upgrader.
Workbench is located in the utility directory on the VR Milling Software CD. This package will identify the controller with no firmware.
The attached document explains how to upgrade the card and the attached MSX file is the firmware that should be loaded.
NextMove ST Build 5403 USB CANopen.zip
(703.41 KiB) Downloaded 853 times
How to reload firmware to a NextMove ST Card.pdf
(58.52 KiB) Downloaded 1151 times
