I recently purchased an Easiturn 3 lathe which is missing its 3 phase motor. Not sure why it was taken off but need to get a replacement.
I was hoping someone could help me with the following;
1.What is the speed that the motor is rated at? I know it is 240v 3ph, but unsure of the speed? Would a 2800 rpm motor be ok?
2.Could someone tell me what pulley size I need for the motor? The pulley on the spindle is 100mm diameter if that helps?
Any help would be appreciated?
Thanks, Oliver
