the computer is not finding the microrouter. the error message says to check that the machine is on (it is) and check the rs232 cable (the rs232 cable seems fine).
i opened the control panel and the control card flashes 8. d3 and d4 are flashing at the same rate.
(leading up to this problem, i was getting 'transmit buffer is full' errors.
switched the rs232 cable and it started working!
however, there is an issue where it sometimes loses the z coordinate zero and plunges down until e-stop is hit. suggestions?
Does it plunge when you home the machine or is it during a program?
sorry for the long time between posts. school was on summer break. it plunges during the program.
inspector x from denford solved this for me. the winding nut was causing resistance. and making the z axis lose zero. proper cleaning silicone lube fixed it.
