X AXIS READING JUST KEEPS GOING UP
chrispotts
Hardware/Software: Denford CNC Microrouter V5 pro
solidworks 2011
Post by chrispotts » Thu 14 Apr , 2016 11:05 am
when I press the "XYZ" function to home the cuter before running the machine the numbers on the X axis position just keep going up without the tool moving anywhere!
I have tried all I can tink of including shutting down the machine and restarting.
With an exam board deadline looming I an in serious panis mode.
ANY sggestions gratefully recieved
Re: X AXIS READING JUST KEEPS GOING UP
Post by Martin » Fri 15 Apr , 2016 16:23 pm
Do any of the axis move?
Can you use the secret home button & jog the axis?
Do any of the axis power up?
Can you check if the drive fuses?
What is the serial number of your machine as we should be able to look back at the electrical record sheet to see what drives are used for the axis.
chrispotts
solidworks 2011
Post by chrispotts » Fri 15 Apr , 2016 16:58 pm
thanks for replying.
After taking the macine apart I found that the drive coupling on the X axis had sheared.
I have been able to order a replacement from Denford.
