FS: Baldor NextMove ST Topboard with USB port Microturn 2000
This is the top board (only) from a Baldor NextMove ST stepper control board as used in my ScanTek 2000 Scanturn (A rebranded Denford Microturn 2000). The dispatch date on my lathe was 2005, and you will note that this board has the USB input as well as the serial port input.
I removed this top board from the lower stepper motor driver board and converted the machine to LinuxCNC control via a parallel port break out board. The machine and bottom part of the card works great, and I can only assume this topcard is also perfectly operational. It booted up just fine and you can view the machine bootup sequence (with ESTOP error flashing on the topcard before I reset the front panel) here:
https://youtu.be/AdjDWLJu58U
Perfect for converting your existing machine to USB control or replacing a failed topcard. (I'm giving away the RS-232 cable that attaches to it, if anybody needs that message me.)
Sticker on the microchip reads: NST002-501D S/N U0504260457
Auction is for the top card pictured and the two mounting spacers and screws only, does not include the bottom stepper controller board or anything else from the Lathe.
The auction is at:
https://www.ebay.com/itm/-/152052851095
Jay
