2004 versa laser VL-300
I have come across one of the above in a school that is not being used - staff seem to think it still works
Its use has been replaced by a larger laser
Its clearly quite old - who can carryout an assessment of this machine?
Is anyone out there still using a machine this old?
I notice the last post in this forum was 2010 (presuming I'm looking in the right place)
Do you think it worth my while to investigate - It would contribute to the processing of student projects
regards
David
Re: 2004 versa laser VL-300
We have one at our school. To test if it is OK you need to try cutting some material. We had to replace the laser a year ago as it no longer was cutting through (same age as that one) so I would factor in a replacement at some point soon around £1100.
thanks Pete will see if I can get it started up
regards
David
Hi David, You will need to check & clean the lenses & optics also.
You can download the VL300 software from the Denford download page, https://www.denfordata.com/downloads/ulsinst-1.30.zip
thank you - I do have the manual that came with the machine - so I will have a look through the maintenance section.
regards
David
