TRIAC FANUC OM-C ATC
Thinking of selling my TRIAC. :( as I don't seem to be using it as much as I had expected to.
All functionality works and comes with laptop and cable for unlimited drip feeding (I have run programmes with 10k plus lines without a problem). The laptop has freeware on it for the drip feed.
She is three phase with servo drives to all axes so accuracy is excellent.
I can also supply a 4Hp (3kW) 18 month old rotary phase converter to run it that has seen very little use if the right deal can be reached.
Comes with a lot of tooling including face mill, drill chuck and collet holder and a few collets and end mills.
The mill has flood coolant and a 6 position autochanger.
The table has seen some misuse in the past but doesn't affect work holding.
I also have several vices and a rotary table, again available for the right deal!
If any of the above is of interest then please get in touch and we can have a chat.
Thanks,
Charlie.
Re: TRIAC FANUC OM-C ATC
Check your PM box Charlie, message sent.
Replied. :)
Still for sale.
Now on ebay (well, it will be at 8pm tonight!)
https://www.ebay.co.uk/itm/141902849876
and RPC
https://www.ebay.co.uk/itm/141902855348
