I have pneumatic cylinder on on milling machine tool changer that has a leaking internal seal. It works on the outward stroke but air exhausts out of the back valve on the return stroke.
Does anyone know if I could replace the internal seal on this cylinder?
If not does anyone have a spare lying around?
The cylinder is a Joucomatic Isoclair 435 50 438 c 25 A 150 (P max 140psi)
WANTED - Deford Triac ATC In/Out cylinder
- CNC Apprentice
- Hardware/Software: 2001 Cyclone with toolchanger and Fanuc 21i control
Serial number - H00913.
Voltage 415V F.L.C 20A 50Hz 3Ph
1997 Triac VMCwith toolchanger and Fanuc O-M control
Serial number - 70826B.
Voltage 415V F.L.C 30A 50Hz 3Ph
- Hardware/Software: .....
4 Quatros
3 Oracs
2 Easiturn atc
12 station lathe atc
Mach 3 - Location: Quatroland
Re: WANTED - Deford Triac ATC In/Out cylinder
i think the ends are crimped on if so no chance, but the item is replaceable for around £15 upwards.
- CNC Apprentice
Hi, I have been quoted £60+p&p, do you a have any recommendations for a cheaper supplier. Thanks
4 Quatros
3 Oracs
2 Easiturn atc
I managed to get a replacement on ebay for £15, but if you want an original you will pay a lot for it.
- CNC Apprentice
Thanks for the replies.
Went to my local pneumatic supplier in Bristol(Harrier Pneumatics) and got a Parker PIA-5025MS-0150 as a direct replacement for £64.
ATC is working fine now.
Thanks for letting us know. Am sure it will help others in the future.
